Getting around the limitations of JavaSound on OS X - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 171 Old 02-26-13, 02:53 PM Thread Starter
REW Author
JohnM's Avatar
John
Thumbs up Getting around the limitations of JavaSound on OS X
John Reekie has produced a great blog post about how to work around the problems Java has on OS X with audio input from Firewire cards, multi-input USB cards and 48kHz sources. You can find the cure for these JavaSound ills at Room EQ Wizard on the Mac - An Input Workaround. Great work John, and thank you!
Edit 12th September: Here is a related post on using HDMI output with REW on OS X, thanks to EmagSamurai: 8 channel HDMI output from REW on the Mac.
Edit 29th June 2014: Use V5.01 beta 21 or later (available here) for OS X 10.7.3 onwards, removes the need for workarounds.
Last edited by JohnM; 06-29-14 at 06:38 AM. Reason: Added link to beta releases that remove need for workarounds
JohnM is online now
post #2 of 171 Old 02-27-13, 07:33 AM
Re: Getting around the limitations of JavaSound on OS X
Thanks John
If anyone using REW on the Mac with one of these specific cases tries the workaround, please do report back here on how it worked out. Thank you
HifiZine is offline
post #3 of 171 Old 02-28-13, 09:33 AM
New Member
Rich G.
I have a 2008 Macbook Pro running OS X 10.8 (Mountain Lion) with a Presonus AudioBox USB. I tried to running REW last night for the first time on the Mac, but couldn't get past the calibration stage. I kept getting Impulse Response and Range errors (I forget the exact wording at the moment). I have no problems at all using the AudioBox USB on my Windows 7 based laptop.
I just came across this blog about Mac/Java and look forward to trying this method out. I'll report my findings once I test it.
Rich G. is offline
post #4 of 171 Old 03-02-13, 08:18 AM
It worked fine with me... Thanks a million!
I had installed today REW 5.01 Beta 13 on my Mac Mini (running under OS X 10.8.2 Mountain Lion). My sound card is a UltraLite-mk3 Hybrid to which I hooked a Behringer ECM8000.
At first, when using REW with the Behringer calibration file, there was no result. I tried to set the level through "check levels" on Preference / Soundcard tab and got only a signal on the "out" display.
I have then tried the "Getting around the limitations of JavaSound on OS X" workaround, which allowed me to see results on the "in" display.
Now I have to understand why I see crazy results... but my room acoustics is far from being simple - hence my quest to analyse it with REW...
pat17 is offline
post #5 of 171 Old 03-11-13, 05:34 PM
Roubi
It did work perfectly for me.
I have a MBP13" from 2009 with 10.6.8 on it. The soundcard is a M-Audio Fast Track Ultra and the mic an ECM8000.
I just followed each of the steps, and it worked.
So a big thank you !
roubi is offline
post #6 of 171 Old 03-11-13, 05:36 PM
roubi wrote: View Post
I have a MBP13" from 2009 with 10.6.8 on it. The soundcard is a M-Audio Fast Track Ultra and the mic and ECM8000.
EarlK is online now
post #7 of 171 Old 03-12-13, 04:52 AM
roubi and pat17, glad it worked for you. I was wondering if there was an extra (half) step needed to set the soundcard to 44.1kHz, but it doesn't seem to be needed (I'm assuming at this point that REW/JS does it). Thank you for posting your result
HifiZine is offline
post #8 of 171 Old 03-12-13, 04:56 AM
Roubi
I actually changer the frequency setting in my fast track ultra control panel to 44.1, but I didn't try leaving it at 48000. Everybody at the same frequency can not be wrong !
roubi is offline
post #9 of 171 Old 03-17-13, 05:55 AM
New Member
Thank you very much John
This post helped me get the system working. I use an RME Fireface UC USB interface.
Your REW software is great!
Arnau Olivé
Arnau Olivé is offline
post #10 of 171 Old 04-21-13, 08:01 AM
Im working with a 2007 MacBook (yeah, I know, time for a new computer -- but a solid state hard drive and software updates to 10.7.5 have kept it viable).
Im very new into the measurement game. I have a Behringer UCA202 and a UMIK from miniDSP. Since I only have the problem with a 48kHz in put device, do I need to load all of the software discussed in the blog post? If I load the software discussed, do I leave REW input set to 44.1kHz?
Thanks for the help!
chilort is offline
javasound , limitations , os
