So, if you have two 500 watt drivers (EV, Exodus, doesn't matter) that are 8 ohm ((I realize that many sub drivers are 4 ohm - but for my application they are each 8 ohms)...... and an EP4000...
Does it make more sense to:
1. Use stereo and power each driver with each channel of the amp (450w/8 ohm channel, 900 total)
2. Wire the drivers in parallel and bridge the amp. (1957w/4 ohm load)
I've read that some people recommend avoiding bridging amps because of the increased noise floor. Is the choice basically - bridge it for more headroom and power and put up with the extra noise......... Or run in stereo and put up with the reduced output?
Until I read the discussion about noise and bridging - I would have logically just bridged it - since you get twice the power. Any thoughts/comments?
Numbers below are from a "Measuring Amplifiers" thread on AVS:
Stereo, 8 ohms 450
Stereo, 4 ohms 650
Stereo, 2 ohms 1,100
Bridged, 4 ohms 1,957
Bridged, 8 ohms 1,300
Stereo, 8 ohms 450
Stereo, 4 ohms 650
